Got some hubcentric wheel spacers from ebay. Everywhere says you just take your wheels off, put them on and bolt the wheels back on. Problem is on my drum and on the front disk/hub bit where the wheel goes their is a pin and nut which means the spacer wont sit flush. I presume the pin is to help locate the wheel. The nut I am unsure about. Looking at them it looks like they both probably unscrew with a 8 or 6 mill spanner. Is it ok to take these off or will something fall off on the other side?
