chrisstockton
- Apr 18, 2012
- 18
- 7
Hi Guys,
Just looking for some pointers here - the car is a 94 chinq 900cc.
Since we have had it, it stutters quite a bit, it can be when accelerating, and more recently when on a steady throttle. does it for about 2-3 seconds, then it clears and is fine, then does it again. you can liken it to when you used to drive a car that had a choke with it in when the car was cold. LOL.
So its quite low mileage 47K and Ive changed a good few parts on it.
Oil, oil filter, fuel filter, air filter, plugs, ht leads, ecu temp sensor, injector cleaner.
When we bought it the ECU light was on and I traced it to the MAP sensor. I replaced this with a used item from a sporting (hope its the correct one). and the light is no longer on.
Any ideas as its the only thing letting the car down.
Chris
Chris
