Old 22-06-2012   #1
coil - ?
hi,
dose anybody no which of the two wires going into the coil on a 899cc cinq is the - wire? or are they both +.
thanks carl
carl elvis is offline Reply With Quote Quote
Old 23-06-2012   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: coil - ?
Light blue is the positive on both coils.
The other traced colours are the negative. The ECU switches the negative.
D
Old 23-06-2012   #3
Re: coil - ?
any idea if the "omex clubman twin coil rev limiter" would work? The instructions say to connect two wires to the coil -. would this be the other wire, not the light blue?
Old 23-06-2012   #4
Trader Rating: 5
fingers99 has donated!
Re: coil - ?
I think the stock ECU already has a rev limiter. Can't see the Omex over riding this.......... (under-riding, maybe).
Come to think of it, what the hell are you doing with an 899 to need a rev limiter?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 23-06-2012   #5
Re: coil - ?
i dont think here is a inbuilt rev limiter on the 899, had it up to 8,000 and nothing was holding it back. was hoping to set the limit to 6,000. just need to find the - wires and connect it up. anyone no which is the - or are they both +????
Old 23-06-2012   #6
Trader Rating: 5
Re: coil - ?
Could be that the early ones didn't. But the ECU is -- chip apart -- identical to the 1108 SPI ones.
There are two wires to each coil. Both of the ones that are not light blue (one light blue for each coil) are negative.
On the assumption that the later ECUs have a rev cut (someone will advise) then that, and swapping the chips over, might be a cheaper, simpler, option.
Assuming a sporting application, I'd go for either a standalone ECU or an advanced piggy back rather than the stock ECU (just about everything has a rev cut function).
Given a non-sporting application, I'd spend the money on something more fun!
M12 fund 20
Old 23-06-2012   #7
Re: coil - ?
iv just had a look at the Haynes wiring diagram and it says the coil is earthed through the body. not being great with wiring is the earth the same as the negative? here is a link to the instructions http://omextechnology.com/OMRLCLC.pdf
Old 23-06-2012   #8
dave's Avatar
Trader Rating: 10
dave has donated!
Re: coil - ?
gaffer tape a tobacco tin to the back of throttle pedal, will limit the revs
Likes Restorer liked this post
THIS IS WHY TORIES CANT CLAIM HINDSIGHT! https://www.youtube.com/watch?v=bQDPQ8bz7cU
Old 23-06-2012   #9
Re: coil - ?
Quote Originally Posted by carl elvis View Post
Hi: Yes, In Autoelectrics Earth & Negative are the same thing.
Andy
Restorer is offline Reply With Quote Quote
Old 23-06-2012   #10
Re: coil - ?
so dose that mean the - is the body or the wire that isnt the blue wire???
Old 23-06-2012   #11
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Re: coil - ?
The wires that aren't light blue are the earths/negatives, but they earth through the ECU,
What rev counter are you using?
D
Old 26-06-2012   #12
Re: coil - ?
Quote Originally Posted by rallycinq View Post
D
im going to run a stack gauge and a omex clubman twincoil rev limiter.
have you ever fitted one to any of your cinqs?
(T) Is it possible to change mk2 16v coil to mk1 16v coil? ryn079 Punto (Mk2/2b) 5 17-12-2010 05:26
(T) What coil do I need? Alex1985 X1/9 2 29-07-2010 17:37
(T) coil jonboy739 Punto (Mk2/2b) 28 05-12-2008 21:10
(T) which coil to get garsenior Stilo 30 05-12-2007 21:39
(G) Coil Problems Smithy33 Punto (Mk2/2b) 1 18-11-2006 21:44
