Thread Tools
Old 17-06-2012   #1
RhysSmoove has donated!
Clutch has dropped!!
Hi
Just got my '99 Seicento Sporting and I was driving along, went to change to 4th and heard a snapping sound and the clutch pedal hit the floor. When I pull it up, it just pings back down again...
I checked the service history and it says that in Feb 2012 it had a new clutch cable... so does this mean the whole clutch is toast and how much are parts?
Any advice welcome because clutches are not my strong point!
Rhys
RhysSmoove is offline Reply With Quote Quote
Old 17-06-2012   #2
Ouby has donated!
Re: Clutch has dropped!!
Quote Originally Posted by RhysSmoove View Post
.... clutches are not my strong point!
They are not Fiat Siecento's strong point either
There is an improved/stronger clutch cable available but....
if the cable has snapped again -you're overdue for a new clutch!
Ouby is offline Reply With Quote Quote
Old 17-06-2012   #3
Quote Originally Posted by Ouby View Post
Thanks for you're help, one thing I do know is that clutch chnages involve the gearbox, so lots of labour costs from garages? But I know a few mechanics and I have a basic knowledge myself.
Old 17-06-2012   #4
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
its not a particularly hard task, buy yourself a haynes and set aside a day (2 perhaps if you have no helping hands).
Make sure you get a new thrust bearing with the clutch you buy and check the condition of the pressure plate before refitting it.
If any of that confuses you don't worry, once you read through the process in a haynes it will all makes sense.
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 17-06-2012   #5
Ouby has donated!
Quote Originally Posted by blu73 View Post
....once you read through the process in a haynes it will all makes sense.
A Haynes???
Ah, you old folk & your books
Look in the guides section & there is a -How To: Change a clutch on a cinq
Old 17-06-2012   #6
It isn't necessarily the cable, it could be the linkage on the pedal assembly. Ours went just before Christmas and I assumed it was the cable but turned out the linkage had snapped, the short one with a ball joint on either end. Had a new clutch anyway, including a cable, but had to get a second hand pedal assembly to rob the part off as a new one from Fiat was over 70 + VAT. There's a thread about this here https://www.fiatforum.com/cinquecent...-sei-02-a.html . If it is this you'll still need a new clutch though.
Also, there's a possibility it is the plastic fulcrum but that's less likely, I think you'd be able to tell.
Ian.
Thanks RhysSmoove thanked for this post
GrumpyOldMan is offline Reply With Quote Quote
Old 17-06-2012   #7
Quote Originally Posted by GrumpyOldMan View Post
Ian.
I think I read you're post earlier on when I was looking for explainations. I checked the metal rod above the pedal with the ball joints on either end and they look relatively new...
But anyway, thanks for you're advice and I will make sure I have a good look. The only problem is my car is stuck down some road though!
Rhys
Old 17-06-2012   #8
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
A Haynes???
I prefer not to get oil all over my laptop or phone.. having the manual means you can sit there and not have to move all your tools before you go in the house because you don't trust the pikey locals if you need to refer to it.
Also my haynes is an added security device, it sits on the parcel shelf as is to say, "Don't steal me, i'll just break down on you!"
Likes Ouby liked this post
Old 19-06-2012   #9
Hi, just thought I'd update you guys that i have found the fault! It was the cylinder in ther clutch that a gasket had gone... not bad that the clutch mechanism has lasted 13 years (it was the original part!). It was about time for it to be replaced...
Cheers for the help
(and btw blu73, I'd prefer a haynes any day too!)
Rhys
Thread Tools
(T) Clutch pressure dropped Dar Sedg Stilo 1 09-11-2011 01:54
(G) Shes been dropped :) Jamieb Cinquecento / Seicento 12 08-09-2011 22:31
(OT) nearly dropped dead vessey19 Grande Punto 8 04-04-2011 21:04
Clutch pedal dropped and needs bleeding Stilo 1.9JTD cook66 Newbie Central 4 30-05-2007 18:25
(T) clutch dropped to the floor c.watkins Bravo / Brava 7 05-04-2005 14:32
