Thread Tools
Old 05-05-2005   #1
Talking Rocker cover spraying????
Hi all, im thinkin bout spraying my rocker to match broom yellow of car with some high temp stuff but was wondering wot procedure is to prep n do it? Wanna go yellow cus gonna get strut brace n spray that yellow too
Guess who's back!!!!
MintySport is offline Reply With Quote Quote
Old 05-05-2005   #2
bonking bunny
binki's Avatar
binki has donated!
Re: Rocker cover spraying????
best is to get it bead blasted
I am official Fiat forum mascot
Claire says so
click me click me click me
Quote Originally Posted by Alfie
feeling your pain but what dave usually says about stuff is right
binki is offline Reply With Quote Quote
Old 05-05-2005   #3
arc
this is where i stand
arc has donated!
yup, what the wabbit said
minor pickyness, its a cam cover - not a rocker cover.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 05-05-2005   #4
cinqsandminis has donated!
Ireland
If it hasn't been painted, just clean it with white spirit and a wire brush, stick it in your oven at 50-60 deg C for 20 mins and spray with whatever colour you like to get a nice shiny finish.
Sig cancelled due to lack of interest...
cinqsandminis is offline Reply With Quote Quote
Old 05-05-2005   #5
get it powder coated it wont cost alot
aaronwillis is offline Reply With Quote Quote
Old 05-05-2005   #6
Trader Rating: 3
Dan has donated!
What do you call alot?
1.4 16v cinq complete 'ish'
Dan is offline Reply With Quote Quote
Old 05-05-2005   #7
Unhappy Re: Rocker cover spraying????
in response to earlier comment......put it in the oven!!
1 my mum would freak out if she came to make a shepards pie n saw a lump of fiats finest metal in there!
n 2, what use does putting it in the oven make?? could you then even spray acrylic paint on it, but then surely it would burn off?
Old 05-05-2005   #8
Principality Retained :)
Trader Rating: 3
arseofbox has donated!
Using High Temp paint then Baking it cures the paint..like having to wait for the engine to heat up to do the same thing...and risk damaging the paint surface putting the part on the car!
arseofbox is offline Reply With Quote Quote
Old 06-05-2005   #9
Red face Re: Rocker cover spraying????
but cinqsandminis said to put it in the oven first then spray????
could it not be poss to use ordinary acrylic??
wud best poss solution be to whip cover off, clean it with degreaser, let it dry, sand it down bit, spray good thick coat on then bake it in oven for bit?
is it good idea to mask off oil hole and round bottom of cover?
Old 06-05-2005   #10
Ireland
If there is any trace of oil on the cover (which is aluminium and tricky to get paint to stick to) the paint will flake off easily after it has dried. This part of the car doesn't get hot enough to justify using high temp paint, If you clean it properly, prime it then spray it you will do a decent job. Sticking it in the oven at 50 degrees (slightly warmer than your head) will neither damage the paint or cause it to burn, but it will improve adhesion, dry it quicker and give a smoother finish.
Don't bother masking unless it is your first time using an aerosol to spray something....
Old 06-05-2005   #11
soooooo, you saying i shud just clean it up, give it rub down with wire brush?? then what primer should i use? grey, white, red oxide? then just spray it with acrylic n bake it for short time n it shouldnt flake off?
Old 06-05-2005   #12
Ireland
Thats pretty much it. Clean it, warm it, prime with grey primer, warm it and spray with acrylic. I'll post a pic of my sexy black one later....
Old 06-05-2005   #13
well my punto gt cover cost bout 30 pound and looks really good
Old 09-05-2005   #14
I used to put engine parts in the dishwasher. Brings em up luvly if you wash them with Jizer first.
primeruss is offline Reply With Quote Quote
Old 09-05-2005   #15
Trader Rating: 1
mase has donated!
Gary Golf Champion, SikTrix BMX Champion
Quote Originally Posted by cinqsandminis
sounds like a plan batman. 1 question tho.
can you just randomly leave the cover off while doing this? or should u cover the cam with cling film or something?
R97 cinq 1242 <Ex Team Anthracite >
(now sold)
mase is offline Reply With Quote Quote
Thread Tools
(T) Punto Rocker Cover bazd123 Punto (Mk2/2b) 4 10-04-2005 22:10
(T) Rocker Cover on 899 Grayedout Cinquecento / Seicento 5 19-11-2004 23:57
(T) Torque settings for Rocker cover fixings bravomygoodman Bravo / Brava 1 19-06-2004 01:54
(S) Spraying The Rocker Cover? How? dawozere Cinquecento / Seicento 8 13-02-2004 18:58
(T) punto rocker cover chuckie Cinquecento / Seicento 3 12-02-2003 00:20
