Technical Mcrich chip... GET ONE!
Suffolk
Just 2 let everyone know that i bought a mcrich chip and fitted it at the weekend and wow what a difference! Why?
* Absolute bargin
* So easy to fit ( & im a girl!)
* Fantastic response
* Accelerates alot quicker
* Alot smoother 2 drive
* Uses less petrol!
Theres no other mod 4 £40 thats gonna give you this kind of performance increase!
Michael u r a genius! (y)
yeah i have nothing againced the chip... its great and does exactly what it says. but i did have a few probs with the cinq after a week or so after fitting.. all of which seemed to cure themselves after putting the cinq chip back in and the problems never returned. but i also had other probs with the cinq that i know wernt related so the probs with the mckrich chip might have been caused by the other problems etc. if you get me :)
Cinq 1.4 - what spec is your engine that you've fitted the chip to ??
What year is your car ?
Looks like I'm going to need one of these chips very soon !!
John
Hi John,
Engine has only raid airfilter and bosch super4 plugs,just fitted sportex backbox and everything is fine.my cinq is a 98 R but i got a secondhand ecu off a 96 cinq and fitted chip to that.
Here's another glowing testament for these chips.........
I just bought another Cinq Sport . This was a non-runner as the guy was told there was a problem with the immobiliser . He had new keys made at £200 , and then a garage had the car for 2 weeks & gave it back to him as they couldn't fix it .
I've just fitted a McCrick chip & it started up FIRST time !!
It drives great , more peppy than my cinq .
John
One of these chips sounds like just the thing I need.
Would one work ok in a 93/94 899cc cinq?
Also, i search for the name "McCrick" in the members list to PM him but no matches were found so how do I get one
No the chip only works on the 1108 ECU AFAIK :(
Hmm, not too sure, cos after '95, both Cinq's used the same model of ECU (MM 16F) with different mappings, so assuming the injector's are the same (cos Id be surprised if they changed), then TECHNICALLY yes, it SHOULD work...
But thats me hypothesising,and seen as I didn't design the mapping, I cant really say much on it...
the ECU may be the same, but the map would be different surely. I don't recall ever hearing of it being tested on an 899.
But then dan did say a 93/94 899.. so spanner in the works on that one!
