FIAT Auto Specialist Team
Old 23-04-2012   #1
What To Write????
F1A7 5EICEN7O's Avatar
F1A7 5EICEN7O has donated!
slight judder in low gears
basically i noticed today that when i change into second gear from first the car sort of hits a flat spot and judders and then its ok. At first i thought i nearly stalled but then it kept on doing it over and over. its only when taking off from being sat still and then when changing to second.
i will mention it has been bucketing it down today too and it was only a short journey.
The oil level is fine. i dont know what it could possibly be. I have half a tank of fresh petrol too.
Thanks.
For Sale:
2000 Seicento Sporting
Cinq/Sei 899cc Throttle Body 'Bob'
F1A7 5EICEN7O is offline Reply With Quote Quote
Old 23-04-2012   #2
"La Cucaracha"
adr1ean's Avatar
adr1ean has donated!
Spain
Re: slight judder in low gears
in my opinion, it sounds like lack of air/fuel or too much of it so quick check: fuel, flame and air. when did you last change/clean the fuel filter, the air filter and the spark plugs? Does it act the same when having a warm engine or only cold?
Impossible is nothing!
- Fiat-less -
adr1ean is offline Reply With Quote Quote
(T) slight engine judder when at idle matt1976 Stilo 9 14-11-2012 14:05
(T) Slight judder in idle philipb82 Stilo 1 14-12-2011 14:05
(T) Slight judder when lifting off the acclerator blackpool Panda (Classic) 1 11-04-2011 20:18
engine/clutch judder when changing low gears and pulling away stu graham Newbie Central 4 22-01-2009 02:11
(G) Slight judder/grind when i brake. Randomman Punto (Mk2/2b) 2 10-11-2006 22:05
