Thread Tools
Old 16-04-2012   #1
899 cooling issues
when i start my 899 all is well but after its warmed up to 90c it crries on getting hotter this is after being stood for 2 years , i put this down to either the thermostat or the rad needs flushing but i have drained and refilled the expansion tank and will flush the rad pronto, could this also be down to the thermostat being stuck also wheres the temp sensor on 899 cinq engine or shall i follow the wire from the side of the rad
cheeky cinqy is offline Reply With Quote Quote
Old 16-04-2012   #2
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: 899 cooling issues
Does the fan come on when it gets up to temp?
Eklipze3k is offline Reply With Quote Quote
Old 16-04-2012   #3
David C has donated!
The temperature sensor for the gauge is on the front corner of the cylinder head at the belt end.
The fan is switched by the old style thermo-switch on the side of the rad.
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is offline Reply With Quote Quote
Old 16-04-2012   #4
no the fan dont turn on at all thats why i wanted to find out where the temp sensor is lol and could it be the thermostat or is that nothing to do with the fan cheers guys x
Old 16-04-2012   #5
If the rad is still cold (or cool) when the engine is over 90 then the stat is suspect.
If however the rad is hot when the gauge is well over 90 when you need to look at the fan circuit.
I'm not sure at what temperature the fan switch works, but it will be over 90, not at 90.
Old 16-04-2012   #6
Also remember that the fan circuit is still live when the ignition is off.
So careful with fingers near the fan!
Old 16-04-2012   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Check that the fan is working by shorting the switch connector with a paperclip. If the paperclip glows, a) don't touch it, and b) the fan is seized.
This assumes you've checked the fuse is intact and live first.
D
Old 30-04-2016   #8
Netherlands
Quote Originally Posted by David C View Post
To dust of an old topic
What does the sensor do on the thermostat housing?
Peanut01 is offline Reply With Quote Quote
Old 30-04-2016   #9
Quote Originally Posted by Peanut01 View Post
Temperature sensor for the ECU.
Old 30-04-2016   #10
Netherlands
Thank you!
Thread Tools
(T) Cooling issues... booya257 Cinquecento / Seicento 8 05-01-2010 19:03
(T) 1.2 cooling system issues. symonh2000 Bravo / Brava 3 15-05-2009 19:04
(G) cooling issues arc Cinquecento / Seicento 8 03-10-2008 16:32
(T) Heting and cooling issues Mike St Helens Punto (Mk2/2b) 0 20-03-2007 15:18
(G) Cinq 899 issues! garyaird11 Cinquecento / Seicento 4 04-10-2006 10:32
