Styling LED Sidelights
South Coast:Drives: Skoda
Is there a way of getting the sidelights to come on without the main bulb (like when on parking lights) on my cinq sx?
I bought LED sidelights, but they arent that clear when you have the main bulb on dim aswell.
Also, is it possible to have a switch so I can turn on and off the main bulbs?
I hope that made sense???
yeah, pull the fuse out of the dim dip relay. Look at the fuse box, its a 7.5A fuse that isnt near the rest of them. its near a relay (dimdip relay)
To make it switchable, add a switch in there somewhere!
The dim-dip system has been a requirement on UK spec cars since 1988, it is possible that your cars were ex-Irish imports because we do not have the dim-dip system here or else you just missed the subtle change in brightness when the dim-dips come on.
You can also just disconnect the dim dip resistor.
grey area. Seis don't have dim/dip
EDIT:
Dave first press is meant to be sides and the main bulbs on dimly, second press is the main bulb on fully. Then the stalk does main / full beam
