I've been trying to sort out my girlfriend's Seicento, the handbrake did absolutly nothing when it was pulled up when I got it...
Saturday, I adjusted the handbrake cable adjuster bolts under the car, and it seemed to work, however when I released the handbrake, one side siezed fully on...
Yesterday I got a new handbrake lever (the bit that goes from the end of the cable into the drum) and put that on, along with some new shoes... Only problem is that the new shoes are so wide (because they are new) that I had a very hard time putting the drum back on, and they won't retract back any further, so I'm stuck with them fully on...
Is there any way that I can get them to loosen off?.. I was going to try the bleed valve, but neither of the 8mm spanners I have seem to fit properly around the bleed valve. Is it 7.5mm? or 7mm? (I don't have either as a spanner, only socket).
If anyone has got any suggestions it'd be very much appreciated. The car was meant to be ready for my g/f's birthday tomorrow, but if I can't sort it myself then I will have to get someone out to look at it, and that wont be will Saturday
Adam
Adam
