edbremner
Hi All,
Just signed on to the forum, so a big hello to all here.
I have a yellow Cinquecento Sporting, with a burnt out fusebox.
How?
Not entirely sure....my wife ran into the house saying the car was on fire. I wen't out to find there was a penny stuck in the cigarette lighter. Tried to take it out, but just burnt my finger. You would expect the fuse to blow before it burst into flames, but it didn't and by the time we got a fire-extinguisher to it, there was plenty of damage done to the fusebox.
The weird thing is that practically everything is still working, except for (I think) the inside light and the radio.
Obviously some of these fuses are melted into the box, but are still working at the moment.
The main issue is that something is still taking current from the battery, or stuck on even when everything is turned off and although it isn't dragging a lot of power, it is enough to drain the battery over night. Could this be the damaged relay - not turning off? What does this one on the bottom right do?
So, I am open to any advice here:
cheers
eib
ps How did the penny get in there? No idea at all. None of us smoke, so can't remember ever using the lighter since we bought the car, nor keeping any change in the box. It would be easy to blame a child.....but they all look very innocent when asked about this......so a mystery!
How?
- What are my options regarding fixing this?
- I hope it is worth fixing.....but might it be easier to just live with?
- Is it possible to replace the Fusebox alone, or will this mean getting a whole wiring loom, cutting out the fusebox and then joining it back in wire by wire?
- Which fuses are the right bank of 6, Those that are damaged - especially the lower 2? Does anyone have a plan for them? I can't find anything online. Will it match the Seicento?
- How do you get the Fuse box off the car?
- How much spare length on the leads will there be to allow me to join up.
- Do all the wiring looms use the same colour scheme? If this has changed over the years, it might be a right pain to try and replace?
- Anybody got a spare fusebox??
cheers
eib
