Seicento 1100 2002.
Had a quick look today for the switch for the cooling fan but couldn't see it. Where is it located?
The background is that my wife took my daughter (a new learner) out to learn to drive, and spent some time moving off and stopping. The engine overheated and dumped a lot of coolant. I pressure tested the cooling system today using a bit of 8 mm copper pipe plugged into the hose going to the bleed point for the heater. I connected this to a gauge with a tyre valve on it that I test central heating systems with. It let air out at the filler neck at around 13 psi. I retested it at 10 psi and it didn't drop over a 2 hour period. I might get away without replacing the head gasket.
Just need to find the switch so I can bridge it and see if the fan works.
