hey guys just after some info on a service first service ive done and im giving it the works!
fuel filter
oil filter
oil
thermostat
engine flush
coolant flush
coolant
fuel filter
rear brake shoes
handbrake cable
spark plugs
ignition leads
gearbox oil change (as it should have been done at 72,000 but i have no record of it being done and im now around 78,000)
clutch cable
just wondering what type of oil/coolant&antifreeze/plugs i should be using?
the leads im going for are magnecor 8mm in blue.
im changing the thermostat as its faulty.
im sure i need a new rocker cover gasket as well as i have oil leaking down the side of the block although that looks like it could be coming from the thermostat so possibly just the thermostat gasket?
any advice is very much apreciated
fuel filter
oil filter
oil
thermostat
engine flush
coolant flush
coolant
fuel filter
rear brake shoes
handbrake cable
spark plugs
ignition leads
clutch cable
