Old 11-02-2012   #1
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Question Failed MOT emissions
So my cinq failed its emissions (1242 8v).. Results below.
Engine temperature 83.0C
Fast Idle Test:
Engine Speed: 2450 – 2950 rpm - not checked
CO: max 0.300% 1.441 FAIL
HC: max 20ppm 60 PASS
Lambda: 0.97 – 1.03 0.979 PASS
Second Fast Idle Test:
CO: max 0.300% 2.515 FAIL
HC: max 20ppm 100 PASS
Lambda: 0.97 – 1.03 0.941 FAIL
Natural Idle Test:
Engine Speed: 750 - 950 rpm - not checked
CO: max 0.500% 0.404 PASS
Now, not really sure what to do about this other than give the car a good thrash on the way there. Oil & filter are good, air filter is clean, exhaust is ok. Car runs perfect. Thought i would turn down fuel pressure but then thought thats not gonna do anything is it on an injection car? I was thinking if i restrict the amount of air getting through the air filter would that result in ecu chucking in less fuel and thus bringing it down a tad.
Car has quite old petrol in it (with some injector cleaner in it), would that effect the emissions at all?
I just noticed that its down on the test sheet as 1108 not a 1242, would the limits be any different?
Got til Wednesday to sort it - chuck me some opinions.
edit: car has been sat for approx 3 years, i did do about 10 miles thrash on way to MOT.
Likes Red Rocket CINQ liked this post
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 11-02-2012   #2
Trader Rating: 1
Re: Failed MOT emissions
I'd change the fuel then give a really good run out
Brooky is offline Reply With Quote Quote
Old 11-02-2012   #3
Trader Rating: 5
fingers99 has donated!
How old is the oil?
I'd give it a really, really. good thrash, but change the plugs just before it goes in.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 11-02-2012   #4
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Mmm, i was afraid someone would say that.. has over half a tank in it lol. Is prob worth it though i guess
edit: its got fresh plugs and oil. I'm not sure how old the leads are, but they are uprated bosch ones and look to be a good condition - but completely unsure of age.
You reckon its worth swapping the lambda for a known good one?
Old 11-02-2012   #5
Trader Rating: 5
You could always stick the old petrol in one of the many cars on your drive!
May as well change the lambda -- can't do any harm -- if it comes out!
M12 fund 20
Old 11-02-2012   #6
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
ah have faith.. Will just steal the one out the seiT. They'll come out fine.
tbh, i always put high octane fuel in the seiT and the PGT so i don't want to stick it in them - isn't it true petrol loses an octane rating or 2 every year its sat in a tank? Or is that just an old wives tale? I know someone that'll take it though I have convinced my mate that he needs multiple cars like me so he always needs petrol now haha
Old 11-02-2012   #7
you got any leaks from the system?
could be anything really, check exhuast leaks if any lambda then maybe cat, try some fuel treatment called forte.
hf turbo is offline Reply With Quote Quote
Old 11-02-2012   #8
Trader Rating: 5
They say all kinds of stuff about Petrol. Trouble is, it changes all the time, so none of the info is particularly reliable.
M12 fund 20
Old 11-02-2012   #9
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
the exhaust is kinda cobbled together and is all welded. The guy let me under the car at the garage, neither of us could find any leaks at all - to change it would involve cutting and welding which i can't do, i'm 99% the exhaust is ok.
My mate is getting dressed now and bringing one his cars over to put petrol in. Shall i get some high octane stuff to go back in or just get the normal stuff?
Old 11-02-2012   #10
Trader Rating: 5
High octane won't do any harm (probably won't do any good, either, but you never know!). Just a couple of gallons.
M12 fund 20
Old 11-02-2012   #11
arc
this is where i stand
arc has donated!
High lambda reading DOES NOT MEAN THE LAMBDA SENSOR IS FAULTY. Lambda is the AFR (with 1 being stoich) and for an MOT is measured at the tailpipe. All your lambda reading is telling you is that there is too much o2 at the tailpipe.
Changing the fuel can't hurt but I'd be checking the exhaust system again. Cover the tailpipe and check for leaks again. If it was poor fuel then I'd expect to see less of it burning, giving you more HC.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 11-02-2012   #12
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
i know it passed HC but aren't they a bit high anyway?
edit: if stoich is 1... is under 1 lean or rich?
Old 11-02-2012   #13
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
ok scratch that.. its rich as i thought.. so more air or less fuel or both.
Old 11-02-2012   #14
Sweden
Under 1 is rich. By the looks of it I would say that your lambda is not working at all, or knackered. What you should have done (not sure if that was an option) was to stop the engine, unplug the lambda sensor from the plug, restart the engine, let it warm up and see if it would be any different. This would at least give you some diagnostics.
On top of this I would say your CAT is not working at full capacity. And the fueling has only little to do with that, your CO to is excessive, I had similar figures with no CAT at all. With a healthy CAT you should have 10% of the max allowed.
In NL the max figures would be the same for 1.1 and 1.2 (and the same as you quote, this is actually EU wide I think).
Last option is that your engine was not hot enough (water temp. is kind of irrelevant) for the CAT to work at full capacity (not sure where yours is mounted, but by default it is very far from the engine), happened to me last MOT here in NL, the bastards were too lazy to wait for the fan to kick in at least three times, called me telling me emissions are excessive, when I arrived I asked them to keep the car idling for 15 minutes at least, and guess what, CO was down at almost 0 again
Used to own CCS 1.2T, now it's gone
woj is offline Reply With Quote Quote
Old 11-02-2012   #15
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Well i have a known working lambda sensor and a gas analyzer so i can swap them about and see what difference it makes.. The car was properly upto temp, had been idling in there with the fan turning on and off for a while before he did the emission test. The CAT is stock in the original place, but i doubt thats it - most of my cars don't have a CAT and emissions has never been an issue (unless its actually damaged inside).
Was just after some pointers before i went to mess with the car, no point just swapping things at random i never had an issue with emissions before
(T) MOT Failed: Emissions CinqyAbarth Cinquecento / Seicento 15 19-10-2009 20:15
(T) Just failed MOT on CO emissions - help KwikPhix328 Punto (Mk2/2b) 1 03-04-2009 20:15
(G) Failed MOT - emissions nr2k1 Punto (Mk2/2b) 7 27-11-2007 23:39
(G) Mot Failed On Emissions????? riddick Panda (Classic) 4 02-06-2007 22:59
(T) MOT Failed on emissions les Marea 19 24-10-2005 21:34
