Old 01-01-2012   #1
Cinquecento Fuel tank replacement
The tank on my '97 sporting has rusted at the seam and is leaking, so I've bought a new one and now just have to fit it.
I might try this tomorrow, it looks fairly straightforward but not sure how difficult it will be to get the tank around the exhaust.
I will probably put the car in gear, chock the front wheels, and use two jacks on the rear jacking points to get under it, as I don't have any form of ramp.
Does anyone have any adivce for this job? Thanks.
msa1024 is offline Reply With Quote Quote
Old 01-01-2012   #2
andys cinq has donated!
Re: Cinquecento Fuel tank replacement
take the exhaust off!!!! makes it a bit easier and soak all the bolts with plusgas/wd40 and let it soak and repeat each day for 2/3 days cause otherwise they will snap as mine did
Dislikes silvercento disliked this post
andys cinq is offline Reply With Quote Quote
Old 01-01-2012   #3
Quote Originally Posted by andys cinq View Post
Don't really want to faff around with the exhaust, I was hoping I could just move the tank around it.
Thanks for the heads up on the bolts though.
Old 01-01-2012   #4
Trader Rating: 5
fingers99 has donated!
Just drop the exhaust. The hard bit is getting the old fuel pump out -- well worthwhile making up something resembling the factory tool.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 01-01-2012   #5
David C has donated!
I tried to get mine around the exhaust and had to drop it in the end.
It would have been a lot less hassle if I'd taken it off to start with!
The front bolts were like new on mine, but the rear two weren't and one did snap. The problem is rust on the exposed tip so get something on that bit if you can
2003 Audi TT 3.2v6 DSG
2012 Renault Twingo 1.2
x1999 Alfa 156 Selespeed
1994 Fiat Cinq 899cc
David C is online now Reply With Quote Quote
Old 01-01-2012   #6
Fiat nutter
goodgirl156's Avatar
goodgirl156 has donated!
The chap I bought mine from had it done some time ago by fiat? Factory recall apperntly?
We're talking in the last year.
Abarth,Coupe,mr2,4x4panda
goodgirl156 is offline Reply With Quote Quote
Old 01-01-2012   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
You don't have to remove the exhaust, but it does depend on how good your flexi is. If its recent, you can disconnect the exhaust rubbers and swing the pipe out the way.
D
Old 02-01-2012   #8
Quote Originally Posted by rallycinq View Post
That is what I did...... shortly after the flexi failed though
It was an old flexi, but it would have probably kept going for considerably longer.
If I was doing it again I'd disconnect it is the manifold flange to start with and get it out of the way.
Old 02-01-2012   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by David C View Post
That is exactly the danger, hence the reference to a 'recent' flexi.
D
(T) Cinq Sporting Fuel tank Replacement ronb_65 Cinquecento / Seicento 14 02-06-2009 13:47
(G) Cento Fuel Tank Replacement (recall) ChinqSporting Cinquecento / Seicento 12 15-03-2007 10:47
(T) Seicento fuel tank replacement Gazza999 Cinquecento / Seicento 7 29-11-2006 14:46
(T) fuel tank replacement? cjboss Cinquecento / Seicento 3 17-07-2003 08:23
