ockipoki
I have a 02 Seicento 1.1 Sporting (the newer rounded body type) and the clutch pedal is down to the floor. On inspection it is not the clutch cable that has broken but the 4 inch rod that connects directly to the pedal to a hinge at the rear of the footwell. The 4 inch rod has a ball joint and threaded bolt on either end and it is one of these bolts that has snapped, leaving the rod hanging down from the top of the pedal. Hopefully I have attached a pic. The broken rod is the blue in the pic.
I know from another thread that this rod system is because the car is a left hand drive modded to be a right hand drive. Also that my best bet would be to look around local breakers yards for a replacement.
My question is (finally) are there any cars other than the newer Seicento 1.1 Sporting model with this rod system attached to the pedal? Maybe the older Sei's, Cinq's or even the new Fiat 500. I figure the greater the range of cars to look for at a breakers, the better my chance of success.
Thanks.
Thanks.
