phil_harry
Member
My car seems to be losing coolant, from max to min in a few weeks.
It has started doing this since i changed the thermostat and a small hose with a bleed screw that went into the heater matrix.
Only thing is, after i did these repairs, when i filled up the coolant, nothing came out of any of the two bleed screws (maybe i poured it in too fast?) Anyway, not suprisingly over the first week or so after i had done this the water level kept going down and i topped it up, not suprisingly as i assumed as water is being pumped around, air locks would be removed. However, it has been several weeks now and it still keeps losing coolant.
I changed the head gasket about 4 months ago and am getting no steam, mayo or misfiring, and when i start the engine i cant see any visible leaks ( i especially checked the parts i recently changed and the front of the hg)
The only thing is i seem to have some kind of gunk collecting on the top of my airbox (!?) and i have some crystal deposits around the filler cap. When i switch off the engine i can hear air hissing out of the cap.
Would it be possible to loose this amount of coolant through the filler cap? (have just got a new one but cant put it on yet as engine is still warm)
Do you think i should drain my coolant again and bleed it properly?
Phil
Phil
