Old 31-10-2011   #1
lazybones51 has donated!
Mystery battery problem
Hi all
Yesterday I changed the fan motor for the interior blower/heater. To gain access I removed the battery etc... after finishing changing the blower motor I put everything back correctly including the battery, but now the car barely cranks over. The battery is properly connected and I stuck it on the trickle charger for 24 hours just in case I had left the interior light on or something equally as daft on whilst I was working on it, but it made no difference and it still struggles to turn over.
What would have caused the battery to have died like this ? I didn't short it or do anything daft .
Kev.
lazybones51 is offline Reply With Quote Quote
Old 31-10-2011   #2
The Ratter
slugworth1987's Avatar
slugworth1987 has donated!
Re: Mystery battery problem
bad earth?
-Slugworth1987
Wanted:- Fiat Uno Wiper motor with arm
slugworth1987 is offline Reply With Quote Quote
Old 31-10-2011   #3
The only cables I disturbed were the battery terminal connectors, and the two plugs on the blower fan motor. The battery terminals are on properly and the lights etc come on fine and not overly dim, it's just not cranking properly. Is there a separate lead which could have not made it back on the battery terminal ? I didn't notice any.
Old 31-10-2011   #4
The Ratter
the actual battery Ve- lead into the chassie
-Slugworth1987
Old 31-10-2011   #5
Just checked and everything appears well and correct. Maybe when I removed the battery I unsettled some thing in it as I could hear a lot of sloshing of liquid which I have never noticed before, perhaps a dead cell. will pick up a new battery tomorrow and try again
Old 01-11-2011   #6
Ireland
did you disconnect the battery before fitting the new fan unit?
craigk is offline Reply With Quote Quote
Old 01-11-2011   #7
Yes the battery was completly removed from the car , as access to the blower/heater unit is restricted.
Old 02-11-2011   #8
New battery fitted and car started first time, I guess removing the battery must have disturbed something internally causing it to die.
(G) Punto mystery problem. Atticus! Punto (Mk2/2b) 59 21-08-2011 18:32
(T) Mystery Engine Problem Mk1 MadMan0 Punto (Mk1) 14 09-08-2011 11:56
(T) Coolant system mystery problem - help! bennyt Punto (Mk2/2b) 5 24-01-2010 20:19
(T) Mystery problem - specialist garage flummoxed! danmarie30 Punto (Mk2/2b) 3 08-11-2009 18:33
(T) Mystery problem...possibly ECU or earth wire?? karlos85 Punto (Mk2/2b) 3 30-07-2008 20:28
