hi all well i was doing some diy on my car fitting an alarm + remoe central locking and window closure to my 899cc fiat seicento SX and well when it came to the auto window closing this is where i got problems.
the manual said i needed to use two relays but me being me only used one and when it came to pressing down on the drivers side window pop! i heard the fuses go in the box :bang: i checked the fuses and the window one had blown (phew!) well i poped another one in and tried the window again (pressed down) big pop sparks flew out of the fuse box.
centra locking and electric windows killed this time
not the fuses they were fine so i linked a wire over from the sidelight fuse to the central locking and window interface was working untill i pressed down again and pop! fuses had gone again
well i replaced the fuses in the sidelight and then to my suprise they wasnt working no lights at teh front nor the back
so i thought theres got to be more fuses in the car somwhere so i popped the bonet and had a look well behind the battery i found some huge fuses one was a 30A which was blown i replaced it with a bodge job of a little fuse for now till i go to the shop. Well this luckily sorted the windows/central locking problem
but my sidelights still do not work
i then searched around the car for more fuses but i cant seem to find any more then what ive already found and they are all in top working cond
fuses ive found are:
Normal incar fusebox
Big fuses behind battery (back one has its lid on)
ECU ones none control lights
anyone know where there are any more fuses located in the car?
thanx in advance
gaz
thanx in advance
gaz
