Stencils118
- Dec 8, 2010
- 79
- 21
Hey guys, as with pretty much everyone on FF I too have come across a coolant problem\heater problem.
After running my Sei for a bit, the coolant light comes on.. Now, I've bled the system correctly by opening the bleed screw on left hand side by the headlights and the bleed screw coming from the bulk head (Heater matrix perhaps?) and turning on the heater..
Now this is were my logic flies out the window;
- The headlight bleed screw fills up with water - good!
- The bulkhead bleed screw doesn't fill up with water - balls!
- The heater doesn't blow warm air - balls!
- The hose coming from the thermostat housing is cold (when coolant light is on) - hmmm, dodgy thermostat?
- Fan doesn't kick in - dodgy fuse? dodgy rad sensor/switch thing? dodgy fan?
Do you think I should take out the thermostat and check its operation before anything else?
Any advise/pointers would be amazing.. thanks in advance:worship:
