Hi
What he meant to say was remove the connector from the temperature switch half way down the rad between inlet and outlet connections. The connector has two pins bridge those to mimic the over temperature condition.
But the fan will only run when the rad is really hot.
If one of the rad pipes is hot but the other is cold the rad is blocked remove and flush with garden hose, then try a proprietary rad flush package suitable for mixed metal engines. Then remove and flush again...
Ate the hoses to the heater as hot as the hose out of the thermostyat housing?
Noel
Noel
