Hi there,
I would like to change the coolant on my Fiat Seicento S 2002 as it is well below the minimum level. I have read through old posts on these forums and understand that I may need to flush out/drain the old coolant from the system before being able to refill it and then bleed it.
Can anyone please give me a bit of advice on how I go about doing this? For instance where do I drain the system from and where would the bleed valves be situated in this car model?
Also is this an easy job as I have little to no hands on experience with cars. I’d prefer to learn how to do it but if it risks screwing anything up I’d get someone else to do it and watch and learn.
Thanks in advance for any advice.
Cheers.
Cheers.
