Old 03-10-2011   #1
major over fuelling problem :(
Have put a 00 sei sporting engine and box in a 98 cinq sx. I have changed the ecu to cinq sporting so it starts fine but its over fuelling alot so much that lods fuel sits on top of the carb. Help because it wont pass a mot till its sorted. Any solutions? Thanks Euan
euan92 is offline Reply With Quote Quote
Old 03-10-2011   #2
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Re: major over fuelling problem :(
How have you attached the two temp sensors?
D
Old 03-10-2011   #3
Hi everything connected. Thought it might be fuel pump or something?
Old 03-10-2011   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Fuel is regulated on the engine, not by the fuel pump.
Is this an MPi unit you have fitted?
D
Old 03-10-2011   #5
Hi its the thats the same as the one in the cinq sporting if thats any help?
Euan
Old 03-10-2011   #6
Ireland
spi so mate
the carb???
how do you no its over fueling, jut that theres fuel siting there? when these engines are ticking over there is fuel being sprayed onto the butterfly
craigk is offline Reply With Quote Quote
Old 03-10-2011   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
So its SPi, Is the management light on?
D
Old 03-10-2011   #8
No its not but its definetly over fuelling because when it revs the exhaust smokes and stinks of petrol. Plus it sometimes it fires back up through the butterfly.
Euan
Old 03-10-2011   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Sort the timing, and reconnect the lambda.
D
Old 03-10-2011   #10
Ok will have go tomorrow.
Euan
Old 04-10-2011   #11
Iam pretty sure its not the timing because when I bought the donar car it ran fine and havent tampered with the inside of the engine or the belts. Could it be the injector?
Euan
Old 04-10-2011   #12
Ireland
the belts can just slip a tooth themselves
Old 04-10-2011   #13
Autotest Special
rallycinq's Avatar
Trader Rating: 1
If you have got explosions in the TB, the spark must be getting out somehow.
D
Old 04-10-2011   #14
It might be missing becquse it stutters when starting then the rocks alot i have replaced the leads and plugs but maybe its the coilpacks so will replace them when i have the funds. Thanks for the help.
Euan
Old 04-10-2011   #15
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Stupid thought, have you got the right pairs on the coil packs?
D
(T) Major fuelling problem! KPPunto Punto (Mk2/2b) 8 21-03-2011 11:11
(G) Is it an ignition or fuelling problem JustAndy Punto (Mk2/2b) 7 14-01-2011 23:24
(T) major problem ace2727 Grande Punto 17 09-01-2009 14:08
(T) major problem !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! simp0388 Punto (Mk2/2b) 12 20-01-2007 12:56
(T) Major Problem Redpunto2004 Punto (Mk2/2b) 6 13-11-2004 18:02
