Old 01-09-2011   #1
Schumacher ABS and MOT
I have deactivated my ABS as proved too expensive to repair. I replaced my rear bearings on my schumacher with standard ones (it was them failing the MOT that started all this), unplugged and removed the sensors, taken out the power from the ABS and blacked out the ABS light. Only thing I haven't done for complete removal is change the master cylinder. I wondered if anyone else has done this and got an MOT or should I spend a bit more time and money doing a full removal.
(Many thanks to cc1 for all your advice I just wanted to double check before I wasted money on an second MOT only to be sent away)
sherbolton is offline Reply With Quote Quote
Old 01-09-2011   #2
Trader Rating: 3
ycming has donated!
Re: Schumacher ABS and MOT
Once the ABS light comes on , the system should be disable and so should pass an MOT?
That is my thinking anyway.
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 01-09-2011   #3
Benjammo has donated!
Blot in Hell Champion
mots normally have a time limit for you to do the repairs, if its within that time frame they should only test what it failed on, ie the wheel bearings. if its a full test now, well the breaks are still upto scratch, no lights on the dash, wheel bearings are now alright, I'd say go for it and good luck.
Benjammo is offline Reply With Quote Quote
Old 01-09-2011   #4
I already went back to the same MOT guy he said "you can't do that, if its got ABS its got to be tested for the ABS light" and "what did they do take the bulb out!" When we disconnected it the light just stayed on so we did black it out. If it came on and went out as it should then it would have passed. Any advice appreciated.
Old 01-09-2011   #5
Trader Rating: 5
fingers99 has donated!
It seems there is database which lists what had what, IYSWIM.
I'd try another MOT station. Some are more responsive than others.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 01-09-2011   #6
Trader Rating: 1
cc1 has donated!
The speedo pods on Seicento's with ABS are a special as they have an input for the warning light. It is a surface mount LED that will stay on without a constant OK signal applied from the ABS ECU.
You have to take the pod apart and desolder the led. Or install a non ABS pod.
The first thing the examiner looks for is warning lights at ignition on. Then looks for lamps out at engine start up. Simples.
Go to another MOT station and say nothing about what has been done.
My examiner did not Know I had removed the ABS untill I told him. He said " You never told me that" wink, wink. Even though, I could argue that the car is piped up the same as a non ABS version and as long as it passed the roller test is fit for the road.
I have a 16v Bravo disc setup on the front and Punto GT discs on the rear. On the brake test the rear ones failed because the compensators have a problem with the setup. The examiner now won't use the rollers on mine and uses equipment to measure all 4 together. (Classed as custom setup). The reading gives 3 times the stopping power required to pass for my car.
cc1 is offline Reply With Quote Quote
Old 01-09-2011   #7
These are the reasons for failure for an ABS system.
1. The warning lamp
a. is missing
b. does not illuminate
c. does not follow the correct sequence of operation
d. indicates an ABS fault.
If the car still has the ABS unit under the bonnet, and visible sensors etc under the car the tester is right to fail it. It would be a massive job to remove the ABS system altogether as you'd need to fit non ABS brake pipes etc.
You could always wire it up to the oil light!
Likes slugworth1987 liked this post
Tiffx19 is offline Reply With Quote Quote
Old 02-09-2011   #8
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Skate Boarder Champion
Quote Originally Posted by sherbolton View Post
Just outta interest, how much was a set of rear bearings for ABS model?
Finn - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT, Panda Mania 1242 mpi
blu73 is offline Reply With Quote Quote
Old 02-09-2011   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Quote Originally Posted by blu73 View Post
http://www.shop4parts.co.uk/?name=st...=3581&sku=9737
113 each, apparently.
or
Roughly six times the price of non ABS ones.
D
Likes blu73 liked this post
Old 02-09-2011   #10
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
OUCH! I have ABS on the sei, its only on 40k miles though so touch wood i won't ever have to touch them.. I know from experience even the hub nuts are significantly more expensive
Old 03-09-2011   #11
Mine has only done 63k! Just looking for parts now to change the master cylinder. Good job we have 2 cars. Will prob be selling soon if anyone is interested.
Old 03-09-2011   #12
Its Adventure Time!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Well if we are being honest the ABS is shocking, i can defo stop a no ABS model faster.
Old 03-09-2011   #13
Trader Rating: 1
cc1 has donated!
You will need both rear compensators with fiting bracket to mount on the servo/master cylinder. A flaring toolkit, About 2 reels of Kunifer pipe with fitting, inc inline conectors as you will struggle to pipe the rears in one go with the engine in.
It's a big job...
Spending 300 on 2 bearings and a sensor might sound alot but when compaired to a full service at a garage it's not that bad.
At 63k miles the discs/drums, dampers, bushes, head gasket, etc, could be about ready if original.
Old 03-09-2011   #14
Trader Rating: 3
ycming has donated!
I'll got the 2 bias valve with the pipes if you need and the bracket . Also have a old master cylinder, but for 25 quid you might as fit a new one!
Is the servo the same?
Ming
Old 03-09-2011   #15
Trader Rating: 1
cc1 has donated!
Quote Originally Posted by ycming View Post
Ming
Same servo.
(G) Mk2 Punto 1.2 8v 2000 - ABS or Non-ABS Brakes corky Punto (Mk2/2b) 3 19-09-2010 19:51
Schumacher Ffoxy Leisure Lounge 9 15-08-2009 00:08
(T) Installing ABS to a non ABS car sjladopoulos Barchetta 15 16-04-2007 16:02
(T) Seicento Schumacher abs problem. denosaur Cinquecento / Seicento 5 04-01-2007 19:35
