The problem you will have when fitting pre-fabricated replacement pipes is the steering rack amongst other thing is in the way. Kunifer bends easy'ish so can be fed down behind the rack but is still a pain to do as the fuel pipes are there.
You have to remove the header tank and intake manifold for access.
