Old 06-07-2011   #1
MKoers has donated!
Netherlands
Best tyre width for 14 6J wheels
I need some new tyres for my new wheels.
The wheels are 14" 6J.
I have found some Yokohama's A539.
But I'm not sure what width is best for me 175 (70 euro's a piece) or 185 (83 euro's a piece).
It's not the money that counts but rubbing in the arches.
This friday the will be rolled and the current 7J wheels will be replaced by these.
I test fitted the new wheels and the clearance to the trailing arm on the back is the same so it should come inside the arch.
I'm afraid that the 185 is to wide and will stick outside of the wheel.
Does anyone have these tyres on a 6j wheels and do the tyres stick out?
Maybe pictures?
MKoers is offline Reply With Quote Quote
Old 06-07-2011   #2
Trader Rating: 1
Re: Best tyre width for 14 6J wheels
195/45/14 on a 6j rim, no scrubbage but the suspension was fairly stiff
Brooky is offline Reply With Quote Quote
Old 06-07-2011   #3
You can use the following sizes with 6x14" rims.
175/65R14-205/55R14-185/65R14-185/60R14
Dislikes vatza disliked this post
baha is offline Reply With Quote Quote
Old 06-07-2011   #4
Stick your own title
mrcinquecento's Avatar
mrcinquecento has donated!
Quote Originally Posted by Brooky View Post
Attachment 92340
exactly what i have, even down to the colour of the car and compomotive mo's
www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier
98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi
mrcinquecento is offline Reply With Quote Quote
Old 06-07-2011   #5
RIP L181 VBB
AppleSei's Avatar
Trader Rating: 4
AppleSei has donated!
Cricket Craziness Champion
Be aware Yoko A539 tyres are now discontinued as a model to choose from in their range
Dont know what stock is like but eventually there is going to be none available eventually so maybe worth having a backup model just in case the above scenario occurs and you have your heart set on this particular tyre
I had these tyres in 195/45/14 and i cant recommend them enough
2001 Modded Sei Sporting - GONE!!
MY ACCIDENT THREAD - BE CAREFUL OUT THERE! - http://www.fiatforum.com/leisure-lou...cky-alive.html
AppleSei is offline Reply With Quote Quote
Old 06-07-2011   #6
MKoers has donated!
Netherlands
I do have 15mm spacers on the back to make the wheels fit.
I will order them now and see what happens haha
Old 08-07-2011   #7
MKoers has donated!
Netherlands
Arches are rolled.
Got the 40mm drop on the back now.
Even with the old 7J wheels it's quite allright. They still hit but the the 6J wheels should resolve that.
Old 08-07-2011   #8
Trader Rating: 5
fingers99 has donated!
As I think I told you some time ago, 195/45/1s are the best choice. Firstly because they're cheaper in performance brands, secondly cos you'll need all the widthh you can get in a turbo car. Uniroyal Rainsports are a good performance per pound choice, as are Falkens (but the Falkens do not, IMHO, suit cars with stiff suspension in thar size).
WTH, I'm still concerned that your choice of rear spacer is extreme. I've fitted 195/45/14s on 6J Compos with 35 offset and 3mm spacers on the rear. Too much offset at the rear ruins turn in (and will force contact with the arches. What ET are the new wheels?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 08-07-2011   #9
MKoers has donated!
Netherlands
New wheels have an ET of 35.
Stil the 15mm spacers are needed.
I test fitted the wheels and I have about 3mm of clearance from the wheels to the trailing arm.
Also I currently have 195's and as there still hitting the arches I'm not going to take the risk.
Maybe if I see the 185 have enough clearance the next tyres will be 195 again.
Still the turbo project is a long term project.
Atleast another 4 to 5 months I guess. Money is not growing on the tree outside my house would be great though
Old 08-07-2011   #10
Trader Rating: 5
Something is very wrong. Take it to someone who knows Centos. The only possible cause of contact with the arches given that set up is the size of the spacers. Lots of people here have run 35 Compos with the set up I describe with no issues (or, with 35mm + drops, light contact with the inner arches). With 35et, 195/45/14s and a rear disk conversion you don't even need the 3mm spacers!
You are risking your safety and that of others if you proceed.
If money is scarce, why fit more expensive tyres?
M12 fund 20
Old 09-07-2011   #11
MKoers has donated!
Netherlands
I have original parts alround.
Checked it out multiple times.
Only thing I can image is that the wheelbearings are less wide then the ones that were on there.
Old 09-07-2011   #12
Trader Rating: 5
I've never seen narrower ones. And they're one peice with the hub (or should be). Something is fubared. There are a fair few very knowledgeable Cento folk in the Netherlands..........
M12 fund 20
Old 09-07-2011   #13
Trader Rating: 3
whitz has donated!
Bomber Bob Champion
well ive got a buckled swing arm that can be seen and causes contact
Ash
if its cheap its generally cheap for a reason
whitz is offline Reply With Quote Quote
Old 09-07-2011   #14
Trader Rating: 5
That, or a badly twisted chassis would do it. But hopefully there's another explanation here.
M12 fund 20
Old 09-07-2011   #15
MKoers has donated!
Netherlands
I checked it out.
Everything is straight and as it should be.
I'm wondering how you run 195/45/14 on 7J wheels with a 40mm drop without rubbing.
As a test I bolted my wheels to a standard seicento abarth and with a 40mm drop that would definitly hit the arches.
When we drove around it even catches.
(S) tyre width on steel wheels alfatastic 500 11 13-10-2009 17:38
(T) What is maximum tyre width you can get ..... yellow_peril_08 Panda 15 01-06-2008 11:08
(S) tyre width on HLX honey_monster Marea 2 31-10-2006 20:52
17x8J?? What width tyre ne1l Leisure Lounge 8 26-05-2006 23:56
(S) wheel spacers needed for 5.5inch width wheels? CinqyAbarth Cinquecento / Seicento 1 10-09-2005 12:26
