aquilaalba
- Jul 4, 2010
- 7
- 2
My Seicento 900 SX failed big time on emissions, I've got one week to get it sorted for a re-test, I was searching for a solution, but failed so far - need your help, guys. To start, I bought it as faulty, had short circuit to chassis on the left front indicator, that blew two fuses. Battery was completely flat for over a week, car has 41000 miles on the clock and apart from emissions being too high it passed on everything else. I've bought VAG cable and checked for faults, it came up with the following (screenshot):
After resetting the faults it seemed to be better, but went back to as previous. It seems to missfire when revving, has passed all tests on IAW ECU, on gauges shows temperature raising as it warms up, lamba in the lower right corner goes into the red (rich) as soon as I touch the accelerator. Not sure what should happen there, as never used the software before. As said, it seems that it reads the temperature, pressure, lambda readings - but it seems like it doesn't take any action when lambda is showing it's running too rich in fuel. Please advise. Thanks.
