hey man a post just for you.
i am sure the standard bolts on a cento are 30mm or 32mm long (measured from where the thread starts) and the only wobbly bolts i can find are 30mm long, so they would def work if u were using the correst offset wheels, how ever if u were using spacers they might not b quite long enough, on paper anyway!
i kno younger modder has 34 offset bravo wheels on his cento with standard length bolts and no spacers, it depends wat size tyres u are using.
u said u need them 5mm longer, so the offset of the wheels u are tryin to fit is 35mm yea? like the uno?
i guess u could always try it with 30mm bolts an no spacers an 175/50/14 tyres an c how much rubbing u get!
