Technical 1.2 16v swap tips please?
Rochester, Kent
hey all
its beginning to look like im going for the 1242 16v engine swap into my 99 sei sporting.
i am picking up the following items from a mk1 punto sporting (so it should all be spi, right?)
1242 16v engine
inlet and exhaust manifolds
downpipe / lambda sensor
wiring loom
ecu
door locks
ignition barrel
keys
fuel pump
is there anything else i will need off the car?
also, any tips for doing the engine swap?
i plan on taking my time doing it, as well as servicing the engine while its out the car, changing the head gasket etc.
cheers!
hey all
1242 16v engine
wiring loom
ecu
door locks
ignition barrel
keys
fuel pump
cheers!
as far as im aware punto sporting is mpi, i just after doing a punto 75 conversion and it was mpi
i think you might need the engine loom but dont quote me on it because i may be wrong,
even doing the 75 conversion i did need to make a spacer for the altenator and then the exhaust had to be welded up which although seems small these are the little bits that take that extra bit of time to do,
but there are a few more people on here which have gone 16v so im sure they can let you no a bit more :)
