knightcento
My gearbox has been a little bit difficult to use for a while now, especially when cold. But over the last couple of days it seems to have got much worse to the point where sometimes you can't get certain gears at all, 1st and reverse in particular but also 2nd quite alot.
1st/2nd just doesn't always go in and reverse sometimes makes the painfull grinding noise as though though the clutch wasn't pressed down properly.
I also noticed earlier that when I started the car with it half in first (gearstick wasn't pushed all the way into 1st) but with the clutch pressed down, the gearstick started shaking quite alot. Surely with the clutch pressed down there's no connection between engine/transmission so no vibrations should be transferred to the gearstick
Will new transmission oil help?
