Fuct_it_up
Hello again all. Yesterday, i became the proud owner of a lovely 50k mile 1242 75 mpi engine. woo hoo. Anyway, my brother is fitting it for me as i'm a little cack handed with the spanners, and he's relishing the challenge of getting it to run on mpi. we had a bit of a discussion, and came up with some possible solutions for the problems outlined in the "sticky" on this subject.
Firstly, wiring. and i quote pete:
"you would need to have the Punto 75 ecu and engine bay wiring loom mated up to your cento - not too easy as the Punto ecu's sit on the opposite side of the engine bay."
How about mating it to a sei mpi loom? if not, why not mount the ecu the other side??
again i quote pete:
"The 75's ecu and injectors need to be supplied with between 2.5 and 3.5 bar of fuel pressure (depending on year of donor car) as opposed to the 1.0 bar that the Centos run at - something which you will need to address"
Will the 75's fuel pressure regulator not sort this problem?
any help, or other suggestions will be gratefully recieved, and thanks to pete for writing the original article in the first place, without that, i wouldn't even be doing the conversion. the cinq would probably be broken for parts by now.
again i quote pete:
