im Axle Specialists
Thread Tools
Old 19-03-2011   #1
One thing after another lol
Hey peeps hows life on the forum iv not been on recently as my laptop died....
My little seicento however has gone and thrown a strop lol...
First thing i noticed after a hill start was my gear changes were getting harder and harder until i arrived at the chinese to collect my order... as i was parking there was a loudish snap as the clutch cable gave way.
i then pushed it onto a straight bit of road to attempt to get it home ...
but i was unable to select any gears and then the car got stuck in year....
The gearstick feels like its in neutral however the car is half selected a gear and is refusing to give up...
I was then towed home with the car half in gear and the gearbox making a little smell unsure if this was clutch or something else...
This ontop of my ECU issues is beginning to ruin the little thing id love to keep it but with Labour and Parts (Especially if the box is f**ked) its becoming an expensive job for a car worth at most 1500 quid
Any suggestions rather than a nice GP 1.9 Mjet lol
Thanks Andrew
New = Alfa Romeo 147 Ducati Corse Q2 170BHP +300LB of Torque!
Old = 100HP Panda '09' Standard But Panel Filter & Greenstuff Brake Pads.
Old = Orange Fiat Seicento SX '02' -Debadged Front/Back-Seicento Sporting 14in Alloy's-Focus Induction Kit-4 x Yokohoma A539
Fiatseicento2002 is offline Reply With Quote Quote
Old 19-03-2011   #2
Sh*tbox Club
Trader Rating: 2
Todger182 has donated!
Re: One thing after another lol
You wanted to do a 16v conversion didn't you?
Now might be a good time to start looking for a 6 speed box, and a pair of new selector cables .
X
Todger182 is offline Reply With Quote Quote
Old 19-03-2011   #3
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Wet shafts or dry shafts box?
D
Old 19-03-2011   #4
Quote Originally Posted by rallycinq View Post
D
Unsure Rally its a 2002 SX MPI if that helps determine it
Old 19-03-2011   #5
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by Fiatseicento2002 View Post
Nope, you'll need to look.
D
Old 19-03-2011   #6
Sh*tbox Club
Trader Rating: 2
They should be dry shafts, something i've discovered with MPI SX's.
Your going to have to find out for definate however.
X
Old 19-03-2011   #7
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by Todger182 View Post
X
Thats the reason for asking, I've seen both in Sei 1108s.
D
Old 19-03-2011   #8
What is the difference ( aesthetically )
Old 19-03-2011   #9
Sh*tbox Club
Trader Rating: 2
With wet shafts it uses the gearbox oil to lubricate underneath the boot. Pull the boot off slightly and low and behold oil drips .
With dry shafts it uses CV gaiter grease all contained in the boot and cup .
X
Old 19-03-2011   #10
Thanks todger ill have a look in the morning should only take a minute as its already on stands with the wheels removed...
Old 21-03-2011   #11
How does the bottom bit of dash on the drivers side come out peeps?
Old 21-03-2011   #12
Sh*tbox Club
Trader Rating: 2
What does the dashboard have to do with gearbox .
Did you check the driveshafts?
X
Old 21-03-2011   #13
I havent looked at the shafts yet....
And im trying to get to the clutch cable any advise
Old 21-03-2011   #14
Sh*tbox Club
Trader Rating: 2
Ahh that would make more sense .
It is a much easier approach with the dash out, downside is there are alot of allen key bolts holding it on.
1 in each corner behind the vents
5 underneath
1 in the middle
Then fuse box needs to be removed and tucked behind.
X
Old 21-03-2011   #15
Right just been out and removed the rubber cover green greasy stuff was present i took some pics too for u to analyse lol
Is it 'Wet' or 'Dry'
Also do i need to get the dash out out or just pulled away ?
ID:	88307   Click image for larger version
Thread Tools
(G) One thing you like, one thing you dislike EmmaM88 Panda 24 04-06-2008 07:33
What is the 1 thing... lizardlace Leisure Lounge 42 22-04-2008 19:34
parents new car/my free run about lol (i told em to get it lol) Dunc Uno Turbo Members Motors (Non-FIAT) 25 07-06-2006 18:37
