Old 11-03-2005   #1
Question Advice on rear hubs
Evening all. I'm a regular lurker but infrequent poster (I just don't know enough about alloys and ICE to be useful most of the time!)
I have a grumbly rear wheel bearing which I want to fix. I have approached Fiat about the cost of a new hub and they want over £50 for one. My local motor factor has an after market item for a shade under £30. The catch is that the aftermarket one doesn't have the cutouts to assist with replacing the rear brake shoes. Having had the brake shoes off a number of times due to sticking rear brakes I know how much of a ball-ache it is to get them off even when the hubs do have cut-outs so I can only imagine how much fun it'll be without them.
My question to you all is: do all after market hubs come without cut-outs? If so is it possible to change the shoes with the hubs in situ or do you have to remove them every time? Is the guy in the motor factors right when he says that the ones that come from Fiat now also have no cut outs?
On a related note how have those who have replaced hubs approached the very high torque specified for the hub nut? My torque wrench won't go up that high and the only ones in the Draper catalogue that do are £350 a pop! I can only assume you just do it up as tight as you can get it with the longest bar you've got!
Thanks in advance guys (and indeed girls)
ClamChowder is offline Reply With Quote Quote
Old 12-03-2005   #2
HP
I was only doing 80...
HP's Avatar
HP has donated!
Re: Advice on rear hubs
I've never bought Fiat bearings, and have changed a few. None of the ones I've bought have cut out's but you can still get the brake shoes in, it's just slightly more fiddly.
Torque setting for the rear hub nuts is 159 lbf ft, my £25 Draper jobby does the trick.
Pete.
"Make something idiot proof and someone will just go and build a better idiot".
HP is offline Reply With Quote Quote
Old 12-03-2005   #3
Chris
Trader Rating: 2
Bushboy has donated!
ive got a used spare one if ur interested. its from some sei rear arms i bought and only used one of the arms, which the hub was perfect on.
as far as im aware they are genuine fiat ones. £10?
Hi!
Bushboy is offline Reply With Quote Quote
Old 12-03-2005   #4
Quote Originally Posted by fixitagaintomorrow
Dunno where you got yours fixit but the £35 one on their website and paper catalogue tops out at 154 Ib ft. Which is probably close enough I guess. Thanks for the info re cutouts and fitting brake shoes though.
Bushboy, I appreciate the offer but since you are in London it'll probably cost the same as a brand new pattern one once you add the postage!
Old 12-03-2005   #5
Patinated Peter
fiat500's Avatar
fiat500 has donated!
I can back up all previous comments.
I used to find bearings wore out exceptionally quickly.
I think its beacause there is no cover at the outer part and it relies on the wheel to protect it.
I fitted covers from a Fiat 126 that are a perfect fit over the hub nut. I can`t see why theses were not fitted from new. Bearings now last much longer.
fiat500 is offline Reply With Quote Quote
Old 12-03-2005   #6
cinqsandminis has donated!
Ireland
Quote Originally Posted by fiat500
I second all of that too. I put Punto alloys on my '97 cinq, but I didn't fit centre caps which let water in and and within 3,000 miles BOTH rear bearings were shot and the car sounded like a jet taking off. I paid €95 (=£60) for the set and fitted them without difficulty, using a 3' power bar to torque them up. The replacements were QH branded and are high quality, but when I looked at the brake cylinders and shoes I needed those too. The replacement bearings had small cutouts so no hassles.
Sig cancelled due to lack of interest...
cinqsandminis is offline Reply With Quote Quote
(S) Updated price list 21/04/2004 Body Stylist Punto (Mk1) 30 09-04-2005 18:02
(G) Rear Wheel Hubs black_cinq Cinquecento / Seicento 26 18-08-2004 13:59
(T) Rear Wheel Hubs black_cinq Cinquecento / Seicento 0 04-08-2004 22:08
(S) rear light advice please!!!! StreetRacer Punto (Mk2/2b) 14 31-07-2004 02:46
(G) DJ Bucho is back DJ_Bucho Cinquecento / Seicento 19 14-05-2004 19:41
