FIAT Auto Specialist Team
Old 17-02-2011   #1
Scuttle cracking
I've just noticed that there are cracks radiating from the mounting of the off-side windscreen wiper pivot on our son's W-reg Seicento. It's obviously metal fatigue, which I suspect is the result of the wiper mechanism being extended for the "conversion" to right-hand drive. The car's done 144,00 miles in rainy Devon but my Cinquecento Sporting had done more miles than that when I parted with it (for panda 100HP) and I don't recall this issue. Any other sufferers? Suggested simple remedies?
babbo_umbro is offline Reply With Quote Quote
Old 17-02-2011   #2
Trader Rating: 3
ycming has donated!
Re: Scuttle cracking
Quote Originally Posted by babbo_umbro View Post
Go single wiper? one of my cinquecento is like that.
What you could, is put a bigger washer under there to spread the load more
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 17-02-2011   #3
is your car import then.. ?? would of been much easier to buy the RHD wiper motor
the invader: http://www.fiatforum.com/members-motors-non-fiat/270284-its-ford.html#post2762950
Quote Originally Posted by The Unknown View Post
IV Seen Bigger
Come to the darkside. We have cookies !
dronenrs is offline Reply With Quote Quote
Old 17-02-2011   #4
Quote Originally Posted by dronenrs View Post
No - but every Fiat I've had - and I've had well over a couple of dozen - has shown some signs of being "converted" from LHD - bar from brake pedal to master cylinder, clutch cable, wiper mechanism, etc. I'm sure the wiper motor stays in the same place and cranks and levers are added to to operate the right-hand wiper.
Old 17-02-2011   #5
Quote Originally Posted by ycming View Post
Ming
I think the big washer is a good first aid, and make sure the bearing's not stiff.
Old 17-02-2011   #6
Sh*tbox Club
Trader Rating: 2
Todger182 has donated!
You have the same problem as me except mine has completely gone and now need a new scuttle pannel .
X
Todger182 is offline Reply With Quote Quote
Old 17-02-2011   #7
Trader Rating: 3
ycming has donated!
Quote Originally Posted by Todger182 View Post
X
Is really easy to convert to single wiper. All you need is another set of cinq/sei linkage for a longer throw by using the pivot that is for the passenger wiper.
Ming
Old 17-02-2011   #8
Sh*tbox Club
Trader Rating: 2
I did a single wiper conversion on my old sei. But I want to keep both on mine as 2 wipers is better than 1 slow moving 1.
Technically because I polish my glass I dont need a wiper at all at 30mph
X
Old 17-02-2011   #9
Trader Rating: 3
ycming has donated!
X
Hmmm mine one just as quick and as slow as 2 wipers :P.
Ming
Old 17-02-2011   #10
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
the only cars that are not converted are jap cars (iirc) as they drive on the same side of the road as us... all Europe cars (other then British made) will been originally designed left hand drive
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 17-02-2011   #11
single wiper will be the same speed as its still one rotation on the motor....
clock34 is offline Reply With Quote Quote
Old 17-02-2011   #12
Sh*tbox Club
Trader Rating: 2
But 2 keeps both sides of the screen clear whereas one will have to do both sides, hence why I say slower .
X
Old 18-02-2011   #13
Quote Originally Posted by craigb244 View Post
Exactly - and possibly Australian and Indian I think.
Old 21-02-2011   #14
is annoying.
BlueDan's Avatar
BlueDan has donated!
Nope, Australia is RHD.
Todger, what stuff are you using on your glass?
BlueDan is offline Reply With Quote Quote
Old 22-02-2011   #15
we had the same problem, got a large disc welded to the underside at both wiper pivots, happened at 40k miles after 6 years, FIAT said "no", so we had it repaired at our local bodyshop. But make sure that the wiper linkage is striped and re-built, cause the first time this was not done and 2 weeks later the crack returned, 2years on and its fine, touch wood
Thanks babbo_umbro thanked for this post
sporting 03 is offline Reply With Quote Quote
(G) scuttle panel replacment? GymJunkie Grande Punto 5 01-02-2011 21:38
(G) help to remove the scuttle panel rdanny Bravo / Brava 2 17-11-2010 10:04
(S) scuttle panel SamuraiDragon Punto (Mk2/2b) 7 20-10-2010 22:09
(T) Scuttle shake? symonh2000 Barchetta 2 22-09-2006 22:43
(T) scuttle shake L8ERS Bravo / Brava 2 22-10-2005 23:47
