M mobile360 New member Joined Feb 12, 2010 Messages 105 Points 49 Feb 8, 2011 #1 hi what will happen if the timing is 180 degrees out?
W whitz Patron member Written a guide Joined Aug 24, 2009 Messages 2,400 Points 480 Location Telford Feb 8, 2011 #2 mobile360 said: hi what will happen if the timing is 180 degrees out? Click to expand... the car will backfire and fart though the inlet manifold easy way to get around this without having to retime the engine is swap the HT heads over on the coil packs, so say 1-4 is on coil one swap them over to coil 2 Ash
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Feb 9, 2011 #3 The big question is:- Why do you think its 180 degrees out, what have you been doing? Edit:- Or is that two questions? Edit:- Damn, that makes it three. Cheers D
