Finally had time and tools today to swap the alternator in i got off sie at the NW meet. Got the wheel off, arch liner out and started loosening bolts. The bottom one came out fine, and the top was a pain in the ass to loosen but i loosened it as far as it would go.
..and here is the problem. The engine mount is in the way. The bolt is too long. The head of the bolt was pressed up against the engine mount and wouldnt shift any further. The other end of the bolt was still bolted in. The threads were still biting. No amount of wobbling would release it. Is this normal or has some clown used the wrong bolt?
This is a photo of the troublesome bolt!
