Old 27-01-2011   #1
seicento won,t rev past 3000rpm
hi my seicento sporting 1108 spi wont rev past about 3000 rpm when HOT,when its cold it goes great revs up nice but when it warms up it will not rev past 3000 there are no fault lights coming on,if you take the air filter off when its hot and squirt a bit of petrol down the inlet it will rev up all the way,
i have changed the crank sensor but it is still the same,can anyone help,
big cheese is offline Reply With Quote Quote
Old 27-01-2011   #2
Trader Rating: 1
craigb244 has donated!
spankthemonkey Champion
Re: seicento won,t rev past 3000rpm
does it sound lean as it gets to 3k? could be the injector sticking maybe. or even blocked fuel filter or pump on its way
1997 - White - Cinquecento - PPC featured High boost 16v Turbo
2010 - White - Punto evo GP
craigb244 is offline Reply With Quote Quote
Old 27-01-2011   #3
Hi
When you turn on the ignition does the fault light comeon and then go off.
If the ECU is unhappy it will rev limit the auto to 3000 rpm, but it should also turn the light on as well.
Noel
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Old 27-01-2011   #4
no lights on when driving or when you rev it up,it only happens when the engine is hot,when cold revs and runs fine
Old 27-01-2011   #5
but does the light do the self check when you turn the igniton on and then go out when started up ??
Thanks Pep0 thanked for this post
the invader: http://www.fiatforum.com/members-motors-non-fiat/270284-its-ford.html#post2762950
Quote Originally Posted by The Unknown View Post
IV Seen Bigger
Come to the darkside. We have cookies !
dronenrs is offline Reply With Quote Quote
Old 27-01-2011   #6
will check that tomorrow as the car is not with me now,what are the options if it doe,s come on and then goes off,and what if it don,t come on at all
Old 27-01-2011   #7
Sh*tbox Club
Trader Rating: 2
Todger182 has donated!
If it doesn't come on then suspect a dead bulb.
X
Todger182 is offline Reply With Quote Quote
Old 27-01-2011   #8
and if it comes on and then goe,s out ????????
Old 27-01-2011   #9
Sh*tbox Club
Trader Rating: 2
Then there is something wrong that the ecu isn't detecting.
Then there is lots of things to check .
X
Old 27-01-2011   #10
like what i need help can it be that bad it goes ok when cold
Old 27-01-2011   #11
Elminate one thing at a time
Starting with the bulb as instructed above
New = Alfa Romeo 147 Ducati Corse Q2 170BHP +300LB of Torque!
Old = 100HP Panda '09' Standard But Panel Filter & Greenstuff Brake Pads.
Old = Orange Fiat Seicento SX '02' -Debadged Front/Back-Seicento Sporting 14in Alloy's-Focus Induction Kit-4 x Yokohoma A539
Fiatseicento2002 is offline Reply With Quote Quote
Old 27-01-2011   #12
ok will do that tomorrow
Old 27-01-2011   #13
fia
pingu has donated!
check the crank sensor.
fiat stilo 1.6 2002 dead and gone.
1999 seicento sporting.
pingu is offline Reply With Quote Quote
Old 27-01-2011   #14
Quote Originally Posted by big cheese View Post
Quote Originally Posted by pingu View Post
did you read the thread properly .. like said one thing at a time
IV Seen Bigger
Old 27-01-2011   #15
changed the crank sensor still the same
(G) Wont rev past 2500 rpm!!! spirito de runto Punto (Mk2/2b) 8 09-04-2010 15:19
(T) Car wont rev past 3k silombts Cinquecento / Seicento 7 27-08-2009 12:02
(T) stilo 20v wont rev past 5k tom johnston Stilo 0 09-08-2009 15:43
1.3 Multijet engine, wont rev past 3000 derby allen Lets Talk FIAT 12 01-01-2009 17:35
1979 fiat x1/9 will not rev past 3500 rpm. jack fiat x1/9 Lets Talk FIAT 2 01-02-2007 08:42
