when i went to put the rockerarm back on there is two pushrods that sit higher than the others? do you think i have to turn the engine over to get it off that stroke? Thanks
Tighten down the shaft a couple turns on each nut in turn so that it all lines up. You will always have a couple of valves open wherever you turn the engine.
