The car has a 1.2 16v fitted with a 48mm TB amongst other things and failed the MOT on emissions. At the time I just left it as the car was pissing me off ( i had to withdraw from a couple of events ) and I basically got told that I got what I deserved for bolting stuff onto my car.
Now that I am in the frame of mind to work on it I thought I would check the lambda sensor which turned out to be working ok but the ignition seemed well advanced.
I am from a different era when all we had were distributors and carbs. I have no understanding of ECU's and injection and the thought of messing about with maps or building megasquirts fills me with dread. I have approached three businesses in the area looking to see about having Megasquirt /Omex fitted but pinning anyone down to actually do the work is akin to chasing a pea around a plate.
On Monday I will check the the cam and crank timing in case I did something wrong when I cured the oil leaks and check for anything else I may have cocked up.
In the meantime, if anyone knows anyone who does remap ECU's or someone who actually is prepared to strap an aftermarket one to my car then please let me know, as the new season approaches and I could do with putting these problems to bed.
Mind you there is an Alfa 147 race car on fleabay, which would solve all the hassle the Cinq is giving me at the moment.
