helicopter_red
Hi following up from my last post about water leak
my problem is loss of water my car runs well otherwise (it is an 899cc)
have checked the oil in engine this is clean
checked rocker cover cap this had mayo (i dont use car much and it was last driven in november apart from mot in january) so not sure if this is due to condensation etc.?
checked water which is rusty as it has been topped up so much do to leaking smells of something (not to sure what)
car seems to run fine from cold start and runs really well untill water is low if not checked (injection light comes on tickover goes high and runs poorly even though it is still not showing overheating on gauge), add water goes back to normal runs fine.
takes ages to warm up if left ticking over, no heat comes from internal heater until you rev the engine and then water gauge goes down fairly quickly as the water circulates, leave to tick over again and it cools down inside car (has the water pump hadditt or has previous owner taken out thermostat, or is it broken)
checked for radiator bleed screws i have one down by headlight but not in hoses going to internal rad, should one be there
does anybody think these could be a head gasket problem ?
only large amounts of water comes from drivers side sill when reversing from drive but the carpets are dry car is parked bonnett pointing downwards
any advise opininons etc welcomed and thanks to everybody that replied to last post
cheers HR
cheers HR
