Thread Tools
Old 20-02-2005   #1
Cinq Sporting Electrical Problem - Brake lights/rear lights
Can anyone out there help me please??
Cinq Sporting 97R
Electrical problem on Fuse 13 (7.5amp). The fuse blows - but not straight away.
With lights on - without pressing the brake, the brake lights also come on
With lights off - press brake and the dash lights (speedo/tacho) come on
Realise there is a short somewhere but unable to find it.
Checked brake switch, and found ok
Anyone have any ideas?
Regards,
namb
UPDATE:
PROBLEM SORTED - THERE WAS A SHORT BETWEEN THE BRAKE AND TAIL LIGHT FILAMENTS. NOTICED WHEN EACH BULB WAS EXAMINED CAREFULLY. THE TAG HOLDING THE FILAMENT HAD OPENED AND BREACHED THE GAP BETWEEN THE FILAMENT POSTS. THIS THEREFORE CAUSED THE SHORT - FUSE BLOWING - ALONG WITH INDUCING THE OTHER CIRCUITS.
MANY THANKS FOR YOUR SUGGESTIONS....
REGARDS,
NAMB
namb is offline Reply With Quote Quote
Old 20-02-2005   #2
Trader Rating: 3
Dan has donated!
Re: Cinq Sporting Electrical Problem - Brake lights/rear lights
Have you replaced any bulbs recently, could be you have the wrong wattage?
I had this, but my dash lights were coming on when i braked.
1.4 16v cinq complete 'ish'
Dan is offline Reply With Quote Quote
Old 20-02-2005   #3
hi friends :waves:
Liam's Avatar
Liam has donated!
Maybe you've replaced a twin filament bulb with a singular, brake lights also sharded with side light, this could be your problem.
Liam
Yes it's really me!
97 Cinq Sporting-RIP 09/10/06 BYE OLD FRIEND
Liam is offline Reply With Quote Quote
Old 20-02-2005   #4
joecinq has donated!
The exact same thing happened to me when i out the reverse bulb into the brake light socket and the brake bulb into the reverse one.
I think this would be what liam said ...
I have put a 10amp fuse in there now - replacing the 7.5 and it has worked for about a month like it
3rd Fiat - luck as good as ever
joecinq is offline Reply With Quote Quote
Thread Tools
(T) Brake Drum problem Redpunto2004 Punto (Mk2/2b) 4 16-11-2004 14:50
(T) Another brake light problem cruisestoke Cinquecento / Seicento 2 01-10-2004 14:31
(T) Brake light staying on when lights on Shakey Cinquecento / Seicento 2 22-09-2004 11:50
(T) Brake lights sort of not working...sometimes Sando Cinquecento / Seicento 2 18-11-2003 06:47
(T) Rear brake lights problem Bois_aiii Cinquecento / Seicento 4 24-09-2003 05:48
