I have done a minor rebuild on my currect 1242 non turbo engine.
I replaced als teh gasket's and cleaned the top of the pistons.
But that time I left the crankshaft in place with the pistons in the cilinders.
This time I want to build an engine that's ready for a turbo.
To do this I will have to replace the piston rods with 16v one's to lower the compression.
I have a couple of questions about this.
How hard is it to do this in you're own garage?
I only have regular tools and a torque wrench.
Can I use a 1242cc engine and place the 16v rods or must it be a 1108cc engine?
Do the cilinders need to be honed?
Do teh cilinders need to be bored to the right size?
Do I need to use the orginal pisons of the engine or the 16v pistons?
How can I switch the pistons on the rods?
I want to replace the piston rings, how to do this?
Is the crankshaft set with special clearance requiremenst or is it just
putting it in place and torque it up?
I would like to have some examples/pictures of how it's done.
As I never took an engine apart that far.
Also good ideas and tips to create the perfect engine are welcome.
