Hey guys,
I seem to have a very odd and wierd problem with my base model Cinq. To begin with it was using up loads of water, so I had the radiator changed and that semed to cure the problem for abit but then it started running in the high 110's, overheating and then using more water up again (which had begun to mix with oil as it ws all brown)
I have since had the head gasket done and the head has been skimmed and shes running in the low 90's and only slightly creeping up in traffic until the fan kicks in.
The problem is that she still seems to be drinking the water, I have had to fill the resevoir fully up in a little over 9 days since the last time. The water is still clean and clear, so there is no mixing.
Any ideas as o where its going, if this is a common problem and easy to fix?
Any suggestion or ideas would be gratefully recieved.
Other than that what a great car!!!
Mark
Mark
