General Rear bumper mounts, mot fail?
happy1966
Hi all, getting my cinq sporting ready for its mot and have noticed that the rear bumper mounts are nearly shot due to rust. They look as bad as the ones shown in the bumper guides on here and as one side includes the towing eye i wondered if it was an mot fail.
Cheers.
it shouldnt do but if mot man thinks it compromises the structure he can use his discretion to fail it on what he pleases e.g rusty wing if he thinks its sharp and could cause damage to a person
mines rusty as hell underneath and theres a hole in one of the drums >.> hope it dont fail on that the brakes and stuff work perfectly so i guess its just on what they deside
call me a tight git but if i was mot man i would fail it for a hole in the drum just because its the brakes and you cant scrimp on brakes part of the mot is a visual check of brake conditions too
[FONT=Verdana, Arial, Helvetica, sans-serif]3.5 Mechanical Brake Components[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Method of Inspection[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]Reason for rejection[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]1. Check the mechanical brake components for[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]a. chafed rods or levers[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]a. a brake rod or lever reduced in thickness by more than 1/3rd[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]b. corroded, frayed or knotted cables[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]b. a brake cable corroded, knotted or with wires broken so that it is weakened significantly[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]c. free rotation of clevis joints between cables and levers (this includes cable linkages between brake pedals and remote mounted servos)[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]c. seizure of clevis joint pivots which causes strain or wear to cables to an extent likely to lead to premature failure of the cable[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]d. a corroded or damaged rod, lever or linkage. Wear in eyes of relay levers, clevis joints, stationary pins or pivots[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]d. serious weakening of any part due to excessive wear, damage or corrosion[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]e. abnormal movement of levers, indicating maladjustment or excessive wear[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]e. abnormal movement of levers indicating maladjustment or excessive wear[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]f. security and excessive wear of brake linings/pads[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]f. a brake lining or pad insecure or less than 1.5mm thick at any point[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]g. contamination of brake discs and drums by leaking brake fluid, oil or grease[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]g. a brake disc or drum contaminated by brake fluid, oil or grease[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]h. the condition and security of brake drums and discs[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]h. a brake disc or drum insecure, cracked or excessively scored, pitted or worn[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]i. presence and security of brake back plates/callipers[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]i. a brake back plate or calliper securing device loose or missing[/FONT] [FONT=Verdana, Arial, Helvetica, sans-serif]j. restriction of free movement[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]j. restricted free movement of brake components[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]k. presence and security of locking devices[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]k. a locking device missing or insecure[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Note: On some vehicles, locking devices may not be obvious. However, if there is evidence of disturbance or change, inform the vehicle presenter[/FONT]
Refer to H. p.s this is the manual its from http://www.ukmot.com/manual.asp
you can buy the rear plates with a new cylinder on it for relitively cheap. but if your doing that mabee look into a rear disk conversion and a punto gt front upgrade... sounds like a good excuse.
ill probs just get the back of the drum im guessing any will fit along as its the same size theres a scrappy down the road ill just pop in there see whats potting around
Are we speaking of the rear drums ? Or the plates that bolts onto the arm ?
Both are pretty cheap new, no need to get second hand.
Plates is around £25 / side from fluffy. Drums are around £20 / side from any local motor factor.
Ming
the back plate the poor things tired and worn out were about do i get them?
