Old 26-06-2010   #1
Overheating in traffic
My daughters Sei (1108 MPI 2003) overhaets when she is in a traffic jam. It is fine otherwise. I assume that the thermostat is working otherwise it would boil on a decent journey and this does not happen. (I am 200miles away so I am making a few guesses here!)
Is there a temp sensing radiator fan switch that controls operation of the electic fan? If not how is the fan operation controlled?
Any help much appreciated
branton rhino is offline Reply With Quote Quote
Old 26-06-2010   #2
types his title here
bean's Avatar
bean has donated!
Re: Overheating in traffic
Normally one of two things:
1. Temp switch in rad.
2. Motor has broken in fan so fan doesn't come on- check fuse for fan under dash to see if it has blown. You will nee to buy a whole new assembly for this.
Mine has broke at the mo and i am just managing by having the car vents blowing hot air at max!
Hope this helps.
Nath
Thanks branton rhino thanked for this post
1242 Cinquecento
bean is offline Reply With Quote Quote
Old 26-06-2010   #3
arc
this is where i stand
arc has donated!
on the MPI there is no fan switch in the rad, it is controlled by the ECU via a relay.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 26-06-2010   #4
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
and the fuse is a maxi fuse behind the battery.
There are two green 30 amp fuses in the holder. If the lid has been replaced upside down you can check the wrong fuse by accident, so check both 30 amp fuses.
D
Old 28-06-2010   #5
Thanks for the help. I understand:
1. The fuse is a 30A maxi behind the battery
2. There is no radiator switch, just a relay controlled by the ecu
3. If I need a new fan motor I have to buy the complete fan/ motor and supporting framework.
If there is no rad switch how does the ecu get a signal to turn on the fan?
Where is the relay between the ecu and fan motor?
How can I check the ecu is sending out a start signal?
Maybe I am being a bit thick here but any help much appreciated.
Regards
Bill
Old 28-06-2010   #6
Trader Rating: 5
fingers99 has donated!
Check that the fan motorworks by jumping it (+ and -) directly.
If the fan doesn't work, you'll probably find it cheaper to fit an aftermarket fan. (As in much cheaper if you can't find one at a scrappy).
Most fan issues are down to faults on the earth side. Temperature signal is from the green temp sensor on the right hand side of the inlet manifold.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 30-06-2010   #7
Another favourite fault mode with the MPI fan is that it comes on initially but slows down then eventually stops. I've had two Schumis do this and on the first one the garage swore blind there was nothing wrong with the fan... eventually it didn't even come on at full blast and then slow down, it just started and ran slowly, almost slow enough to see the blades rotating.
My current Schumi is displaying the initial symptoms and I've got a new fan ready to fit.
In both cases the deterioration has been gradual over a period of weeks, verging on months. Nothing wrong with the fuses or wiring, it's the motor.
The Bravo has gone, replaced by...
2012 500 Lounge
Still got the yellow toy....
2001 Seicento Schumacher
The Professor is offline Reply With Quote Quote
Old 02-07-2010   #8
My daughters 2002 MPI sporting is also having a similar problem. I've checked the fan and it's OK but can anyone tell me which is the relay that supplies the power to the fan?
Regards
Neil
bsafirebird is offline Reply With Quote Quote
Old 04-07-2010   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
Quote Originally Posted by bsafirebird View Post
Regards
Neil
I think its also behind the battery. Have you checked the fuses there and also the fan operation?
D
(T) overheating issue in traffic petebarchetta Panda 20 10-06-2010 18:36
No Traffic Option tommy_8884 I.C.E 1 19-09-2008 23:04
(T) Engine overheating when sat in traffic xxxShazxxx Multipla 2 10-08-2007 14:48
traffic wardens custard Leisure Lounge 13 02-11-2006 00:11
(G) traffic announcement steven0161 Grande Punto 3 13-10-2006 11:29
