Ok, situation is thus:
Upon attempting to start my cinq this evening, i was able to turn the key to "Mar" position, but couldnt turn any further. Believing that pressure on the steering lock may be the problem (despite the car being on level ground), i returned the ignition to off, applied pressure to the steering wheel, and turned the key again.
I then hear a "click" as the steering lock engages, the steering wheel locks in position, and there was no longer any resistance/position stops felt on rotating the igintion key - i can now flip it all the way from off to "mar" with non of the usual position stops. I can't start the car, as the key won't turn past "Mar", and i can't move the steering wheel.
As the problem would appear to be the igition barrel, i break out the haynes manual and following the usual cryptic clues therein, try to remove said ignition barrel to inspect the damage. No dice - whilst i can depress the release toggle in the ignition barrel, and turn the key to "Mar", no amount of pulling on the key will free the ruddy thing.
Is there any other way of removing the igition barrel? Does anyone have any bright ideas that may help? Does anyone recoginse the symptoms and know a work-around? Searching similar threads has not turned up any solutions......
for reference it's an M-reg (pre-immobiliser) with the older metal barrel assembly, not the later plastic variety.
ta,
Dan.
ta,
Dan.
