Technical 900cc TwinAir - who wants one in their Cento?
wow this looks like it could be a good conversion but here is an idea for it,
find an insurance write off one and get the full car, yes i know it will be hard to find, but if you find one it would be a fantastic and new and unique conversion
if some one does it i will defo be watching it closely
I think the downside to this is it's going to be fly by wire, ECU will then throw a wobbler so you would have to convert to fly by wire.
A 900CC twin cylinder engine with a low blow turbo sounds a bit dodgey, but the torque from it would be very interesting. Wonder what the limits of that engine is, whether it can see you up to 130bhp on some big boost.
Wonder if it can be bored out to 1ltr :D.
Errr, no camshaft? Certainly looks like there's one in this video ...
YouTube- Fiat Twin Cylinder Engine exposed
I can't see one there, and I know there isn't one.
Works with air to open and close the valves (hence Multi-Air), this reduces frictional losses and gives you more power. It shows the Multi-Air unit coming from the top of the engine at about 50s into that video
Sion
Sion
So the chain driven camshaft at 1:42 isn't a camshaft then?
Edit: I'm not being rude, I don't know a lot about how engines so clarity is educational :D
I think, even with a complete car, it would be very hard to integrate all the ECUs into a cento.
These wierd modern cars have several ECUs that 'talk' to each other. Miss one out, say body control module, and the other ECUs would fail to perform because they were missing information.
D
I think for simplicity you can't beat one of these. Might be a bit of a squeeze shoehorning it into a Cinq' I think!
So, being a Fiat newbie in every sense of the word, how exactly does the cam operate the valves if not by the lobes opening them at preset timed intervals? Also, how does the whole set up work with both pistons moving up and down together. Would that not cause balance/vibration issues? I am totally confused.:confused: Nice video though.
The concept is that by using a camshaft the timing is fixed the only adjustment available is lift. By using pneumatics the timing is infinitely adjustable as well as the lift allowing the engine to run very efficiently over a greater range of engine speeds.
D
AFAIK there is no throttle body, so you do not have losses of efficency when the butterfly is not completely open. Hence you are forced to go fly by wire. The multiair system controls the opening of the inlet valves operating between the cam lobe and the valves, shutting them before they would normally shut if driven only by the camshaft when the throttle is not completely pushed down. Exhaust valves are moved traditionally.
I'd love to see this engine in a 126, if you look at this video, you can hear the noise resemble the old 2-cylinder engine of 500s and 126s.
Video: http://domus.cdn.pawstream.com/quattroruote/Fiat500TwinAir.flv
It'd make a total sleeper, awesome :D
The only downside, that in the video has a bloody heavy flywheel I think.
EDIT: Timing chains are cheap to mantain, you do not have to change them for many km.
I don't get it. From what i seen,
There is a cam shaft, a crank, and a timing chain. But there isn't a set timing like the traditional engine ?????????
You say the multi air controls the valve opening, is that all controlled by the ECU?
Ming
Ming
The whole induction system is not as you would expect, its all controlled by the ecu. Think halfway towards a Formula one engine where there are no camshafts or valve springs.
D
