Old 27-01-2005   #1
J333EVO has donated!
Cool As requested, pic of OMP gear knob adaptor.
as the title says.
Plus here are the instructions verbatim.
1. Remove the original lever plastic section and cut it at a distance of about 110 -115mm from its base.
2. Carefully screw the adaptor onto the plastic lever (about 10 - 15mm). Do not twist thus preventing the lever from breaking.
3. manually screw the gear knob M234x1.5 onto the adaptor.
I think that last bit is to do with thread size, so if wanting to use a gear knob other than OMP you would need to find out if thats the same, because even from within the range of gear knobs that OMP do there are 2, the Star & Sion that don't fit.
Aaron.
Cinquecento Abarth 1.4 16V
Lancia integrale EVO1
BMW M140i
VW MK5 Golf R32
J333EVO is offline Reply With Quote Quote
(S) Cinq gear knob - New way around the problem Cinq_Sport_BiG_DaVE Cinquecento / Seicento 32 06-09-2005 16:22
(S) fitting an omp adaptor with a momo knob blink_82uk Cinquecento / Seicento 8 15-04-2004 00:47
(G) gear knob d miller Panda (Classic) 1 02-04-2004 04:59
(S) Gear Knob Replacement polecat Marea 0 15-02-2004 22:09
(S) Gear Knob Pete600 Cinquecento / Seicento 10 08-05-2003 05:33
