re: slow build 16v cinq
im a tight arse and there's no punto in the scrappy at the moment
as this engine was out of a brava rather then a punto im having to swap sensor over its all the same except the coolant temp sensor map sensor and the hole for the map
thinking about it il have to see if the punto and brava injector wiring is the same as i didnt take that when i took the loom :S
also been looking for piston rings and shells for the next part after its done but no luck and fiat would want an arm and a leg
Ash
Your not using the manifold off a punto?
I'm using the lower alloy half off the bravo 1.2 16v as it has a plastic 1 way fuel rail (no need to cap a return off as it doesn't have one), and the p[lastic punto top half as it's running all the correct sensors for my Sei ECU.
Ash
