Having replaced all the sensors, radiator and pump because the cooling fan wouldn't run long enough to cool the engine I now find I have an electrical fault on the rad sensor.
I have unpluged and shorted the wires as rec ommend and the fan kick in, but went off very quickly, this happened three times and now I have nothing.
I suspect I have a bad connection on the rad sensor circuit but would like to check the earth for this circuit, can anyone advise where this earth is and if there are any other points to check.
